Interior door handle removal
Posted: Tue Jan 21, 2020 6:28 pm
by Jterry
I need to repair the power window in the rear door of my 64 imperial. I can get the door panel loose but I can't figure out how the door handle is attached to get the panel off. I do have a shop manual but it doesn't have that bit of information in it. Thanks in advance.
Re: Interior door handle removal
Posted: Wed Jan 22, 2020 12:13 am
There is a big Philips head screw holding the handle on . Look down through the oval opening on the door handle area to see it. Imperially , Gary...
Posted: Wed Jan 22, 2020 5:48 pm
by Anixon
You'll need a long-shaft screwdriver to get to that screw.
Posted: Thu Jan 23, 2020 4:18 pm
by Crown64
You will find the Phillips-head screw in the oval opening, as stated above, about two inches behind the chrome portion of the handle. Loosen the screw until you can wiggle the handle fore and aft, and side to side. If you loosen too much, the clamp may fall into the enclosed portion of the armrest.
Charles
Posted: Fri Jan 24, 2020 9:20 am
by Jterry
Thanks guys, I'll look today.
Posted: Mon Feb 17, 2020 6:30 am
by Telford
That door handle got me on mine too.
