1959 Imperial
Posted: Wed May 25, 2022 8:11 pm
Good Day All
Helping a friend trying to resurrect a '59 Imperial convertible. This car was brought to his shop in pieces (MANY boxes).
I am helping with the wiring. A "Painless" harness was purchased, so that is our starting point. This is not being restored to OEM. We do have a FSM with schematics.
This car is equipped with both a manual and automatic turn signal cancelling switches. (?) One on the dash (manual), one mounted on the steering column (automatic). The turn signal relay has 14 terminals.
The automatic cancelling switch is broken so we would like to eliminate it. Not sure if the stock T.S. relay is functional or not.
The question is: Can the auto cancelling switch and stock relay be eliminated? Would one re-wire it like a later model mopar? If so any particular year?
Another question concerning the auto cancel switch. The switch has a small roller that looks similar to a later model horn switch. If it does, and the switch is eliminated, looking for thoughts on having a working horn. (Short of just mounting a button on the dash).
Thanks to all who respond
