66 Imperial Convertible - NC
At first glance this looks like it might be in pretty rough shape, but looking closer it doesn't look too bad actually. It obviously needs a new top, and some cleaning up, and a paint job, but it appears to be very original and even has it's service card still under the hood. Could be turned into a nice cruiser if you get it for the right price! I think the $8900 may be a little high though.
https://charlotte.craigslist.org/cto/d/ ... 64322.html
Re: 66 Imperial Convertible - NC
Info copied from the ad.
Extremely Rare, only 514 built!! These are high end collector cars restored. All original and fully loaded with 440 engine and automatic tranny. Solid, virtually rust free body. Lot drives, power top works as it should, car needs TLC. May consider trading, sent pictures of what you have.
Phone or text preferred.
The rusty patch job on the nose would make worry. And if it has that rust on the body, I would be looking closely at the frame. Even still... someone took the time to patch the nose, so maybe it's just surface rust.
Loaded with Options !
