1959 Imperial speedo pinion gear
JerryFromAussie
Post by JerryFromAussie »
Hi,
I am looking for TF iron cast speedo drive gear ( nylon head white 16 teeth ).
Can Anybody help ? . It was a big job to fix a speedometer and now what is left is to get the nylon 16 tooth nylon pinion gear for it.
Regards Jerry
Re: 1959 Imperial speedo pinion gear
I would keep an eye out for someone that is parting out an Imperial in the classifieds section on this forum, or if you notice someone on ebay selling several Imperial parts, you can contact them about the part you need.
