Body Mounts 1964
Posted: Sat Jan 25, 2020 8:07 am
by Ottawa Mike
I just bought body mounts from Metro for my 1964 Crown. I am not sure what size (thickness) of mounts go in the front under the rad and can someone confirm that there are two spots where there are no mounts. Last bolts in the trunk and under the dash?
Mike
Re: Body Mounts 1964
Posted: Sat Jan 25, 2020 10:47 am
Here’s what my originals look like under the radiator core support on my ‘64 Impvertible.
I’ll check the others.
Posted: Sat Jan 25, 2020 11:25 am
Here’s mine back to front. It doesn’t appear that there’s any rubber bushings between the frame and floor at the very back or below the A pillar.
Posted: Mon Jan 27, 2020 10:49 am
by Ottawa Mike
Thank you, this really helps. This confirms some of what I was thinking. Ups my confidence. In the front I suspect that if I put in the same type of mounts that you have the front will be too low. When i got my car the doors would not open because the front was bolted down too low.
I am not sure your mounts are original based on the hardware. I have two generations of old mounts. A real puzzle.
If you ever want to change your mounts I may be able to help. I bought new mounts and expect to have them installed by the end of March.
Ottawa
Mike
Posted: Mon Jan 27, 2020 11:58 am
If you wouldn’t mind posting a picture of the ones you believe are the original style I’d appreciate it.
And thanks!
Posted: Mon Jan 27, 2020 3:55 pm
by Ottawa Mike
- Not this wiil work
Posted: Mon Jan 27, 2020 4:00 pm
by Ottawa Mike
First pic is what i think are the original hardware for 1964 body mounts. There are six different parts. This in not including the rubber.
The second pic is a rubber mount which i am not sure where it goes. Front?
Posted: Mon Jan 27, 2020 4:56 pm
"Here’s what my originals look like under the radiator core support on my ‘64 Impvertible.
I’ll check the others."
Detmatt any idea how to replace those bushings under the Rad.support ?
Posted: Mon Jan 27, 2020 5:36 pm
gary h wrote: Mon Jan 27, 2020 4:56 pm
I have no idea. I’ve still really only just begun to work on this car and I have no previous experience with the generations preceding the ‘67s. I will say that I would be shocked if my convertible has ever been apart far enough to change these body mount bushings but 56 years is a long time so one never knows.
Posted: Tue Jan 28, 2020 12:21 am
by Ottawa Mike
DetMatt1 wrote: Mon Jan 27, 2020 5:36 pm
