1959 Imperial Crown Southampton Restoration
Re: 1959 Imperial Crown Southampton Restoration
Now in the paint shop for color change, with a photo of what it will look like when repainted.
Going to look great with a nice fresh coat of paint. Looks like a real paint job and not a maaco paint job :)
For some reason the Gray Rose Metallic does not reproduce well in photos. In fact the bottom photo is the most accurate color, not the car photo.
It is in fact a very rare color for 1959, no brochures show it and I have only found a few. I call it mauve.
You doing Clear coat or Enamel ?
Base coat/clear coat. The guy has a system for show cars, several coats of clear sanded between coats, then the final coat is sanded (1500 grit) and then polished. Looks like the car is encased in a glass shield!
The only bad part, it don't look original, but I can live with that!
I am stumped again, I just bought another 59 Imperial. No trim tag, only vin tag, and I am trying to match the upholstery material for ordering new stuff from SMS. I feel sure this is original upholstery but others have said it is NOT original.
Has anyone ever seen seats like this?
Second question: The ignition key has been lost along the line. Can a locksmith make a new key in the car, or must the switch be removed and taken to a locksmith?
