1952 Hardtop Newport Coupe VIN Code
Stummy
Post by Stummy »
Hey guys,
who can decode the vin from my chrysler?
Thanks for your help.
Greetings Bastian
Re: 1952 Hardtop Newport Coupe VIN Code
Hey Stummy... I can't find a 1952 "Newport" Imperial. Are you sure it is an Imperial? I'm not an expert on these years, so I may not be aware of these.
Looking up the serial number it appears to fall into the range of the Imperials, so if it is, then it would be a Custom Imperial (C-54). I believe that is the shorter wheelbase style from those years as the Crown model would have been longer.
Saw the discussion over here viewtopic.php?f=4&t=367
Sounds like it is an Imperial, so I learned something today! :)
Stummy
Post by Stummy »
