Autopilot indicator repair
Posted: Mon Jun 08, 2020 9:29 pm
by Dan
Hello
I was wondering if anyone know what type of plastic the indicator for the Autopilot is and what glue might work.
I have the piece that is missing and would like to glue it back together hopefully.
I would be interested in purchasing a replacement if the price is not outrageous.
Re: Autopilot indicator repair
Posted: Mon Jun 08, 2020 10:12 pm
I personally would use a little jbweld. Be careful and use just a little bit and I promise that little plastic piece will never come off again... at least not at the same spot.
Posted: Tue Jun 09, 2020 9:49 am
by Dan
ImperialAtom wrote: Mon Jun 08, 2020 10:12 pm
I have used JBWeld but the gray stuff. I see they have one for plastic, you are suggesting that one?
Posted: Tue Jun 09, 2020 10:31 am
If they have one for plastic then it might work even better. The plastic version may be designed to have a little flex to it to avoid breaking the plastic it's sticking to - don't know. I'm used to the typical gray stuff too, and never had a problem with it sticking to anything. Just remember to use a little, you shouldn't need much, and wipe away any excess that squirts out to avoid it showing. If there's any gray showing, just paint it black and you'll never see it.
Posted: Tue Jun 09, 2020 11:33 am
by Dan
Thank you. I'll keep everyone posted.
Posted: Wed Jun 10, 2020 9:13 am
I use JB brand clear 5 minute epoxy on things like this.
Posted: Wed Jun 10, 2020 9:16 am
didn't even know they made a clear version... that would be ideal for things like this.
Posted: Thu Jun 18, 2020 4:16 pm
by Dan
Just an update, got it repaired. I'm not painting it as it will not show.
Sorry for the bit of blurriness.
I have it all filed down. It fits on fine. Now for the install. Still working on an allen wrench to fit the ring that drives this dial. I did learn via the service manual, that the way to reach it is with the allen screw at the top.
The service manual mentions a gauge tool C-3844 for setting the accelerator linkage. Anyone know what the thickness of the gauge would be? I guess it would be winning the lottery to actually find this tool.
Posted: Thu Jun 18, 2020 8:39 pm
Repair looks good. Probably stronger than it was before.
Agree with you assumption - not likely to find a C-3844, but I'm sure there's a more practical tool that can do the same thing.
Posted: Fri Jun 19, 2020 9:50 am
by Dan
ImperialAtom wrote: Thu Jun 18, 2020 8:39 pm
It is just a gauge. So the concern is what is the measurement of the gauge in order to set the accelerator rod connection properly. Then I can just use what ever comes up to that measurement.
