1955 Imperial VIN Location
In order to complete the title transfer of my '55 Imperial, I have to have the VIN verified by the Auto Club. They need to see two VIN locations. I found the number on the driver's door post (that was easy). Can anyone help me find a second VIN location? The plate on the firewall above the steering column does not have the VIN. Is there one stamped on the frame? Thanks!
Paul
Paul
1955 Imperial
Re: 1955 Imperial VIN Location
Is it up near the windshield or is that too old for that?
Didn't see anything up by the windshield. Perhaps it's somewhere on the frame?
1955 Imperial
I also seem to have posted this in the wrong part of the forum. Sorry about that.
1955 Imperial
NP - moved it to general section.ecvpaul wrote: Fri Jul 10, 2020 10:16 pm I also seem to have posted this in the wrong part of the forum. Sorry about that.
how can I tell if an imperial is a Southampton?
Re: 1956 Imperial VIN Location
I'm looking to buy an 1956 imperial and the owner said he thinks its the Southampton edition. VIN C5610635 I CANT FIND ANYWAY TO CHECK IF ITS A TRUR SOUTHAMPTON
There should be a data plate under the hood that will have several numbers and letters on it. If you decode that, you can know for sure if it's a southampton model.
Short of doing that, you can also tell just by looking at it. In 56, there was a Southampton model for 2 door and 4 door. The 2 door models are all Southampton, so if you only see 2 doors, it's a southampton. If you see 4 doors, look at the B piller (the pillar between the windows of the front and back doors). If that pillar exists then it's a sedan, but if you roll down all 4 windows and there's no B pillar between the front and back windows, then that is a Southampton. When you roll the windows down on a southampton 4 door, you can swing your arms from the front to the back, it's wide open!
so there's a vehicle No C6510635 tights it. I also would like to know if its an Crown,Custom,Or La Barron
The only thing you can tell from the VIN is that it's a Chrysler product (the C in the VIN) and it's a 1956 because of the 2 digit year after the C. No other data is available based on the VIN, you'll have to find the data plate on the car to know more.
