The power valence windows on my 66 were working great when I got it (70 F), then stopped completely when it was a cooler day (45 F), then when it warmed up a bit (60 F) it started working again on one side.
Any idea what might be causing that?
Valence Window Not Working
Re: Valence Window Not Working
By now, the grease inside the gear drive has turned to the consistency of peanut butter. Each vent window motor assembly should be removed, and the drive gear mechanism cleaned and re-greased. White lithium grease works well for this. At the same time, if the driven gear shows any signs of stripped teeth, and it's not too far gone, true up the beveled slots with a file and clean well before re-assembly.
1964 Imperial Crown Convertible
1969 Cadillac DeVille Convertible
1970 Cadillac Fleetwood Brougham
1989 Cadillac Fleetwood
1972 Lincoln Continental
Thanks, that makes sense on why temperature is affecting it.
